johnhors: because strain gages seem to work well only in areas of small to no strain gradients, and work not so well in the really interesting areas, the high strain gradient areas, then they would appear to be of limited utility for correlation with numerical analysis. I have only limited experience with correlation of strain gage readings with FEA, so perhaps others could enlighten the rest of us ignorants.
Photoelastic coatings work very well in many many cases. There is also a lot of research in thermoelastic measurement techniques that use infrared to detect tiny changes in temperature which sometimes can be correlated very well with strains and stresses.
Every measurement technique, as well as every numerical method, has problems, so I wouldn't discount any technique just because it has limitations, I would only make sure those limitations weren't distorting my results.
