I had originally drafted a different reply, where I touched on the specific comments made by GTTofAK. However, I’ve thought better of it. GTTofAK is dancing around the point, so me replying to each superfluous (and largely incorrect) comment would only detract from the discussion. So, instead, I’ll provide a detailed post on the actual point of the matter:
Does ENSO have the ability to have a major impact on the long-term trend of global climate?
--------What is ENSO and What Does it Do?-------
To answer this, we need to understand what ENSO is and what it does.
A nice rundown of ENSO can be found here or
here, from NOAA. Some history on ENSO research can be
found here. The write-up on the impacts of ENSO can be
found here.
In brief, ENSO relates to the weakening (during El Nino) and strengthening (during La Nina) of Pacific equatorial trade winds.
During El Nino years, when trade winds are weak, warm water that usually pools in the West Pacific moves closer to the surface, where it interacts with the Atmosphere more readily, and is transported eastward.
During La Nina, the strong trade winds cause warm water to pool deeper in the Western Pacific and causes stronger upwelling of cold water in the Eastern Pacific.
ENSO has a profound impact on seasonal climate variability in certain regions. Due to the positive and negative impacts of ENSO on agriculture and society in certain regions, the ability to accurately predict the ENSO state and effect on regional-seasonal weather is very important. Currently, our ability to predict ENSO and its specific seasonal impact on weather in specific regions is rudimentary and often not that accurate. Much effort is being put in to improve our knowledge in this area.
However, it’s very important to differentiate between
predicting seasonal weather variability in certain regions and
modeling long-term global climate. Our inability to predict ENSO
does not, on its own, mean that long-term climate projections are flawed. In order for our inability to predict ENSO to be a significant issue for long-term climate projections, ENSO must have a long-term impact on climate trends. However, logically, the burden of proof is on the asserter (i.e. those that support the anthropogenic climate change theory), so it should be phrased the opposite way – in order for our inability to predict ENSO to
NOT be a significant issue for long-term climate projections, ENSO must
NOT have a long-term impact on climate trends. The science supports this for a variety of reasons, which I’ll outline below.
--------Reasons Why ENSO Does Not Have a Long-Term Impact on Climate Trends-------
1. ENSO is episodic
The first strike against ENSO having a long-term impact on climate trends is that ENSO events are temporary. El Nino’s typically last for 9 months to ~12 month. La Nina’s can last for 1 to 3 years. As ENSO events do not last long, a trend in a particular ENSO event becoming more common and more intense would have to exist in order for ENSO to have any chance* on influencing long-term climate trends (*as described further below (#6, 7 and 8 specifically), even if a trend did exist, this chance is extremely low).
2. ENSO is roughly cyclical
ENSO switches between a positive PDO phase, when El Nino events dominate, and a negative PDO phase, when La Nina events dominate. The duration of the phase varies but has a cycle of roughly 30 years.
No long-term trend of more El Nino’s and less La Nina’s have been observed. So any short-term variable warming cause by the positive PDO phase is roughly balanced by the negative PDO phase. The opposite is also true.
[image link
3. ENSO has no notable long-term increase in the intensity of El Nino’s or La Nina’s
It’s possible that, even if cyclical, ENSO could still have an impact if the intensity of a particular ENSO event was increasing (i.e. stronger El Ninos = warming, colder La Ninas = cooling). However,
there appears to be no notable long-term trend in the intensity of ENSO events in the recent past, let alone the intensity of a particular ENSO state. It might be said that
Trenberth 2002 found that ENSO left a residual impact in the latter half of the 20th century (1950-1998)…of 0.06 deg C. Not per decade, total. Not only is this not significant, it’s also heavily biased by the referenced period. The 1950’s were dominated by La Nina (negative PDO) and the 1990’s where dominated by El Nino (positive PDO). What this 0.06 deg C value really means is that the impact from a negative PDO to a positive PDO is minimal. Addressing a negative PDO period to another negative PDO period would likely have even less of an impact.
Some research does suggest that model projections indicate that the intensity of ENSO events could possibly become stronger as a response to global warming. However, this merely states that the short-term internal variability could be stronger in the future, which is an expected result of global warming. So even if ENSO events become more intense as a result of global warming, it does not follow that they will have an impact on long-term trends.
4. ENSO has had no notable long-term impact on pre-industrial temperature trends
ENSO has been a natural occurrence long before the pre-industrial period. Removed from major anthropogenic CO2 influences, if ENSO had any long-term impacts on climate, they should be evident in paleotemperature reconstructions. However,
global temperatures have been very consistent in the Holocene. There is no evidence of ENSO impacting long-term climate change during the Holocene.
5. ENSO is not a driver
As ENSO has had no notable impact on long-term climate in the past (recent or paleo), it is obviously not a driver of climate change. Nor could it ever. Drivers must be “external” to normal climate, such as solar activity, orbital variance, volcanoes, anthropogenic actions. ENSO is an inherent part of climate. Even if ENSO were to or could possibly change in the future, it wouldn’t do so magically on its own. It would be a feedback to another driver. A possible “change” in ENSO could be a destabilizing of ocean currents. This “tipping point” for climate is unlikely to occur outside a major, calamitous event (i.e. asteroid or super massive volcanoes).
(*I’ll point out that the fact that ENSO is not a driver, on its own, doesn’t mean that that it couldn’t impact long-term climate change (for that you’ll have to take all the other points into consideration). Of course feedbacks can have substantial long-term impacts on climate. However, this does display the myth that ENSO, and not CO2, is driving for long-term global warming.)
6. ENSO only causes surface temperature to temporarily deviate from the “average”. It doesn’t impact the “average”.
A key aspect of ENSO, often forgotten by people that believe ENSO has a long-term impact, is that the “heating” during El Nino years and “cooling” during La Nina years is
relative to recent years. El Nino events will be hotter than “average”, La Nina events will be cooler. However, if, in the long-term, the “average” is warming or cooling, this will become more significant than the short-term internal variability of ENSO. And this is exactly what we see. The 1995 El Nino was cooler than all ENSO neutral years and even all La Nina years in the 21st century. The 1983 El Nino (the 2nd strongest El Nino ever) was cooler than all La Nina years since 1995. In the long-term, the signal dominates the noise.
Another way to look at this is to examine El Nino years against El Nino years, La Nina years against La Nina years and ENSO neutral years against ENSO neutral years. What you see is that, in the long-term, EL Nino years, La Nina years, ENSO neutral years and all of them combined have similar warming trends.
[image
This, to me, is some of the strongest evidence against ENSO having a notable long-term trend on our climate. It simple does not impact the “average”. It merely allows for a temporary deviation from it. So, even in the most absurdly optimistic condition (perpetual La Nina), you’d still have a warming planet and you’d still have an energy balance problem.
7. ENSO does not significantly impact the TOA radiative balance
The two main reasons why ENSO doesn’t impact the “average” is because it is episodic (as discussed in #1) and it does not significantly impact the TOA radiative balance. In order to have a notable impact on long-term climate, the driver or feedback must have a notable impact on the TOA radiative balance in the long-term. Anything else is merely internal variability caused by moving energy around the system – which is what ENSO is mainly about.
Note that I’m not saying that ENSO doesn’t impact TOA at all; it does very slightly impact the TOA radiative balance by affecting cloud cover temporarily.
Mayer et al 2013 found that “TOA net radiation perturbations are small”.
Trenberth et al 2010 states that “The main changes in SSTs throughout the tropics are associated with El Niño Southern Oscillation (ENSO) events in which the dominant changes in energy into an atmospheric column come from ocean heat exchange through evaporation, latent heat release in precipitation, and redistribution of that heat through atmospheric winds.
These changes can be an order of magnitude larger than the net TOA radiation changes” (my emphasis).
If ENSO had a major impact on TOA, you’d expect to see it appear in Ocean Heat Content data. If La Nina’s cooled the earth by impacting TOA then you’d expect to see sharp drops in OHC during strong La Nina years that mimic the surface temperature. The opposite for El Nino years. However, this is not the case. OHC has steadily risen, even throughout the “pause”.
[image
The vast majority of the influence from ENSO events on surface temperatures comes from moving heat around the system, not impacting TOA balance. This is the result of the mechanism of ENSO, which is the moving of hot water to the surface during El Nino, where it interacts with the atmosphere more readily, and pooling it in the deep ocean during La Nina, where it can’t interact with the atmosphere as readily – i.e. temporarily releasing and storing heat.
Meehl et al 2010 examined OHC during “hiatus” periods (negative PDO) and “non-hiatus” periods (positive PDO) and demonstrates that, in keeping with our understanding on ENSO, deep OHC increases faster during negative PDO phases (storing phase) but upper OHC increases faster during positive PDO phases (releasing phase).
Balmaseda et al 2013 shows similar results.
Hoerling et al 2008 wraps things up nicely. They found that “Our results indicate that natural variations internal to the Earth's climate system have had a relatively small impact on the low frequency variations in global mean land temperature. It is therefore extremely unlikely that the recent trajectory of terrestrial warming can be overwhelmed (and become colder than normal) as a consequence of natural variability.”
8. ENSO has no inherent mechanism that could have a major impact on long-term trends
The reason why ENSO doesn’t have a notable impact on long-term trends is because it lacks a necessary mechanism to actually impact long-term trends. ENSO temporarily causes more heat to be stored in (La Nina) or released from (El Nino) the ocean. It does not have a major impact on adding or removing heat from the Earth (i.e. it doesn’t significantly impact TOA). I’ll use an analogy of a hydronic home heating system with a hot water tank for storage. The analogy, like all analogies, is not perfect. I have no doubt that “skeptics” will cherry pick this analogy to death yet it matters very little to the overall point. Hopefully it helps illustrate the mechanism of ENSO to some.
- The home represents Earth.
- The electric water heater represents the Sun.
- The room temperature represents the global surface temperature.
- The hot water tank represents the oceans
- The control valve on the outlet of the hot water tank represents ENSO
- Insulation on your house and around the tank walls represents green house gases
Unlike a normal electric water heater, but quite like the sun, this particular electric heater runs all the time, regardless of room temperature. This isn’t a big problem because the house had terrible insulation and so the heat input from the electric heater closely matched the heat loss through the walls. However, someone started putting insulation into the walls. Now the heat input from the heater is slightly greater than the heat loss through walls.
What’s worse, the control valve on the outlet of the boiler cannot be controlled. It’s normally at 50% open, which we’ll call “neutral” but, seemingly randomly, flips between being slightly more than 50% open, which we’ll call “opEN” state, to slightly less than 50% open, which we’ll called “cLNosed” state. Over the long-term, there’s no notable trend of the control valve being more in the opEN state than the cLNosed state. In the neutral state, the room heats at a fairly steady rate since the insulation has been added. When in the opEN state, more hot water goes to heat the room and the room heats faster but there is less hot water left in the tank. When in the cLNosed state, less water goes to heat the room and the room heats slower but there is more hot water left in the tank.
This past Monday there was a very strong opEN state but this Saturday and Sunday were very strong cLNosed state days, which meant there was an insignificant increase in room temperature for this week. However, the hot water tank temperature continued to rise throughout the week (and months), the room temperature for the past two month increased steadily (since the insulation was added) and more so this past month (when more insulation was added) than the first month, and the strongest opEN day last week was actually colder than the strongest cLNosed state this week.
It’s obvious that the control valve is not responsible for the warming. While the control valve can add considerable noise to the warming trend, it is not responsible for the warming trend. Even if, in the future, we could “fix” the valve to always be in the cLNosed state (which is analogous to some MAGICAL perpetual La Nina state), we still would not fix the problem. The hot water tank would continue to warm and so would the room.
You would still have an energy balance problem where the heat input is exceeding the heat output, even if not all of that heat was going to the room (/atmosphere) but instead was building up in the tank (/oceans).
TL;DR
Q:
A:
No.
