…and this is why we shouldn’t read too much into something from a leaked draft
All of the accusations that the IPCC secretly switched figure 1.4 at the 11th hour solely based on a blog post are completely baseless. The old figure was from a
leaked draft. The image could have been a placeholder. The new image could have been approved long before the leak but wasn’t completed or added to the draft prior to the leak.
What we do know is there was a Lead Author’s Meeting (LAM)
after the leaked draft (SOD – December 2012, 4th LAM – January 2013). At the LAM, comments from the SOD expert review are reviewed. It is very likely that the error in figure 1.4 was discovered
during the SOD expert review, before Foster’s blog post, and commented. The comments were addressed at the LAM and the issue was corrected. To claim that the IPCC changed the image because of the blog post is utterly absurd and completely unfounded.
Trends Matter
The issue is that model projections represent the trends. The exact year-to-year values are not what they are trying to represent. So to apply model projections onto a single year, a hot one at that, and then compare trends
is comparing apples and oranges. The model trends need to be applied to the temperature trend, not the single year.
But regardless of the baseline, as stated above, the trends are what matter. And what do you get when you compare model trends against observed trends (1990-2012)? A very close match. The "average" model run is slightly hotter than observations, mainly for the reasons which I’ve listed before. Both Schmidt et al 2014 and Huber and Knutti 2014 support that.
[image
Emission Scenarios
While anthropogenic CO2 emissions are near the higher emission scenarios, anthropogenic aerosols and volcanic aerosols have been underestimated. This means that the total forcing, which is really what matters (and part of the reason why the IPCC moved to RCP scenarios which relate to forcings), is closer to the middle/lower emission scenarios.
Models obviously cannot predict anthropogenic aerosol emissions and have underestimated them. However, the harm caused by aerosols will mean that these emissions will reduce over time as more pressure is put on governments (i.e. protests in China over air quality). So the cooling forcing of anthropogenic aerosols is very likely to reduce in the future.
The papers that started this thread point to errors in how models handled volcanic aerosols (from smaller volcanic events). This improvement in the science will be used to improve models. This has a minor impact on the short-term predictions and explains some of the discrepancy between models and observations. However, it’s unlikely that this will have a long-term impact on model predictions as volcanic events are episodic.
The point of the matter is that it is incorrect to compare the recent short-term observed trends with the highest forcing scenarios when the forcings have been closer to medium/low-forcing scenarios. Furthermore, as volcanic activity does not have a long-term impact and anthropogenic aerosol emissions are very likely to decrease, the long-term trend is likely to shift towards the high-forcing scenarios without mitigation initiatives.
