Theoretical burst speed of a disk
Ah... the formula must be similar to the one used for circumferential stress (hoop stress) in pressure vessels, but with an equation for centripetal acceleration...
Would I figure that the entire mass was at the radius of gyration?
Am I getting close?...
Thank you,
-Michael
ALBANY SCHENECTADY TROY NY
Michael
This is a pump forum but your title, which, I assume, is the question, doesn't appear to have anything to do with pumps. I'd suggest forum 404 (Mechanical Engineering - Other Topics). However, if you decide to post there, be sure to leave a note here directing replies to that posting. Also you might want to consider posting your question inside the message, not just in the title.
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
