We aquired thermal mass flowmeters to measure compressor outlet flows (in the 70 psig, 8000-10,000 SCFM range), but we get very erratic readings from the instruments. I suspect it has something to do with moisture content (sometimes air is completely saturated), but the manufacturer mentions that air humidity shouldn´t affect the readings that much.
Anyone has succesfully used thermal mass flowmeters for compressed air in those ranges? We use them extensively in blowers and gas flow apps, no problems, but we are baffled by their reading in compressed air. operating conditions and ranges are within calibration specs, only moisture content isn't controlled.
thanks for your comments
