Hello, I've got a general question about FEA and shell intersection: considering the case of two large concrete walls (say about 2 m thick each) that create a T intersection, a finite element model that uses only thick shells elements should consider the stiffness increment due to superposition of real intersection (--> 1 m² section all along the height of the two elements). Do you have any simplified reference to evaluate the stiffness increment in that zone?
Thanks.
Thanks.
