Thickness in different points
fsh27
Industrial
Apr 18, 2016
57
There is any command to analyze thickness of a body in different points?
I´m using NX10
Airin
NX Designer
ANALYSIS --> Molded part validation --> Check Wall Thickness
or ANALYSIS --> More
CSBK
Is the analysis you want to perform what i can see in the image above ?
Then use "Measure Distance", ( You can use the Simple Distance as well) first select the bottom base face as "Start Point",( note, you want to select the face itself and NOT a point on the face.) then tick in the point snap above the graphic window "Point on face", then you can click repeatedly on the top face and for each click / position see the distance.
Is this what you desire ?
Tomas
