mike mufdi
As we are approaching commissioning of the oil plant, use of blinds, and spades will be needed to provide double isolation (spade after valve) . in some locations the lines are tight with very heavy wall thikness making it almost impossible to insert a temp spade with thickness to match the line class. since in theory these spades will not see the actual working pressure, is there anything in the Shell DEP or ASME B31.3 that allows using thinner spades in this situation ?
thanks
thanks
