Rusty55125
- Aug 8, 2006
- 4
What is the correct way to call out a thread for the inside of a bored hole and it's threaded mate. I need to join two components with a fully threaded stud. The hole in the mating parts is 2 inches inside dia. Or is there a std straight thread that I can use?
Do I use the pitch diameter as the reference for both?
Exp: Pitch dia of 2.03 with a 10 threads per inch with a Acme thread.
The threaded stud would then be 2.06 major dia threaded to 10 threads per inch.
Also, not sure which type of thread to use, Acme or straight pipe.
Any suggestions?
Any suggestions?
