  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Threaded hole line color in modeling
LMTDCS
30
Can (how) you change the dashed line color representing the i.d. of a threaded hole in modeling. Now it is the same as the bodly color which is very difficult to see. Much like you can change the color in drafting. ??
Chris
NX8.0
It appears to me that there is not a way to do what you want.
I see that it is possible in "Drafting" to do it, but not in "Modeling">
I hope, for your sake, I am wrong.
It uses whatever is the default arc colour.
You will probably find that your arcs & solids are using the same value of default so they end up the same colour.
Change either one to specific colour using Preferences -> Object, then change the Type to whatever you want to change and specify a colour. This will only apply for the current part but you can change your template parts to make it permanent.
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.4.4, NX8.0.0.25
If you wish to change the default for the future, than what Tony said was accurate, however, you can select the existing 'arcs' while in Modeling as 'curves' and simply edit their display, changing the color to whatever you desire, like any other curve.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
UG/NX Museum:
Well that does seem to work even though the solid and line defaults where different colors in the default settings. I changed the defaults while in the modeling session and that accomplished what I wanted. I think a modeling default color for threads would be helpful. They thought of it in drafting ?? Thanks for all the help!!
Chris
