pejap
- Oct 10, 2023
- 2
I need to add a NGR (neutral grounding resistor) to a Customer specified three-winding transformer with following parameters:
Primary: 46kV, wye-connected with solidly grounded neutral. 46kV system is solidly grounded.
Secondary: 4.16kV, wye-connected. To add NGR on this winding.
Buried delta tertiary (or stabilizing winding): 4.16kV delta connected, corner grounded
Power: 6 MVA
Vector group: YNyn0(d11)
This transformer is used to feed industrial loads and resistance system is also a requirement. NGR will be rated for 10 seconds and the system will trip on the first ground fault.
When it comes to resistance grounded systems in industrial distribution , I am used to working with two-winding transformers containing a delta in one of the windings, which blocks zero sequence current flow from primary system to secondary system and creates “ground fault islands”. In these systems, I only use secondary capacitances to determine the NGR rating.
In this case, however, I am not so confident and I need a validation. I believe that primary charging current (e.g. resulting from 46kV system stray capacitances) will not enter the secondary system during single-line-to-ground fault on secondary (4.16kV) side. I believe that I can calculate secondary charging current by using secondary system capacitances only.
This is what I think happens and I would like your validation or correction:
For this three-winding transformer, the zero sequence model of the transformer connects primary to secondary sides of the system with a T-model where a tertiary zero sequence Z0 impedance is connected to ground.
When I draw a sequence diagram for single-line-to-ground fault on 4.16kV wye (NGR grounded) side of the transformer, the zero sequence charging current from primary side of three-winding transformer would take a path of least impedance and return to primary side of the transformer (e.g. to zero sequence capacitive reactance) via the small tertiary Z0 impedance rather than take a path through secondary and large NGR impedance. In this case, my NGR is sized at 160 ohms and the zero sequence current would see 3*160 = 480 ohms. This NGR impedance is much larger than tertiary Z0 impedance.
1. Am I correct in my assessment or is there another explanation for what happens here?
2. Am I correct in saying that to calculate NGR rating for connection to secondary 4.16kV wye system, I can consider only secondary (4.16kV system) charging currents?
3. For my own curiosity, if this transformer was a two-winding transformer, wye-to-wye where primary was solidly grounded and secondary needs a NGR, then how do you calculate charging current on secondary side of the transformer?
In other words, is there an influence of primary charging current onto secondary charging current?
Thank you
Power: 6 MVA
Thank you
