Hi all,
I will be using a 10-15kpsi (20 US gpm) pump to perform water blasting operations. Due to the existence of different type of paintings and substrate materials to be stripped, I will need the capability of working at different water pressures.
For an electrically driven pump I was wondering if somebody could advise me on energy efficient methods for controlling the ouput pressure of a pump.
Is the use of a VFD a reasonable option? or would a bypass system connected in the output be enought?
The pump is to be used for periods upto 20 minutes, and the total operation per day would probably not exceed 5 hours.
F.
F.
