Through Curve Mesh -Primary Curve List Menu
aussiedesigner
17
Recently when I goto create a new 'through curve mesh' surface, the list menu
for the Primary Curves has disappeared.Which is very annoying!
I've attached an image of what the menu looks like now.
I've restarted NX11 and that hasn't fixed the problem. Not sure if anyone out there
can explain why this has happened??
Thanks in advance.
 https://files.engineering.com/getfile.aspx?folder=0164dff8-7934-467d-a51f-8f2a396a8cb6&file=through_curve_mesh.PNG
Click on the Gear, then Show Collapsed Groups.
Anthony Galante
Senior Support Engineer
NX3 to NX11 with almost every MR (24versions)
