Thrust loads on Pressure Vessels/Process columns. 2
3doorsdwn
162
[First off, let me tell you I am structural (just to let you know this isn’t my field).]
I have always been curious: how do pressure vessel guys determine if the forces from thrust loads (due to platform supports framing in [for example]) are acceptable in magnitude? I always get referred to either 2 things: either Bergman’s paper, or ASME’s code for boilers and pressure vessels. I have a copy of Berman’s paper and it seems to be looking at the vessel as a whole (more than locally). If ASME’s code does have this could you tell me where (maybe a page #).
Thanks in advance!
There are several different pressure vessel handbooks that have design approaches for different clips welded to a shell. Also, WRC 297 and WRC 107 give stresses due to forces on nozzles, and these can be adapted to certain attachments at times.
Thank you JStephen. One question though: could you recommend a handbook that addresses this? (A specific title? It seems like there must be a million pressure vessel handbooks out there. Thanks again.)
PRESSURE VESSEL DESIGN MANUAL
BY DENNIS R.MOSS
GULF PROFESSIONAL PUBLISHING
Bednar's Pressure Vessel Design Handbook has several pages on clips. Megyesy's Pressure Vessel Handbook doesn't seem to cover the topic. I don't have a copy of Moss's book to check it.
piping code ANSI B31 covers thrust on nozzles from safety and relief valves discharges.
