Tie beams 1
newhouse22
Computer
Nov 3, 2015
Dear sirs,
is there any risk for me without tie beams for this home ?
Yes.
Is that confined masonry construction? Looks like Africa? There are some good recommendations online at EERI albeit they are just recommendations.
Recommend getting a local engineer who knows construction in your area to provide specific feedback.
Thank you for the comment,. what if I use 16mm T/S for slab beams ? slab will be my ground level.
under the slab will be leave empty because place is not level.
each column base is 4ft deep from the ground(4x4x4) and its 4ft x 4ft x 1ft concrete base. (12mm T/S)
all 18 columns. no earthquakes here in sri lanka :)
You really need a local engineer. There are so many factors that impact all of that. Unfortunately, there is no blanket answer for anything in the structural world. Good luck.
