cdixonm
- Jun 7, 2016
- 12
I am building a model where I have two layers of material. The outer layer is growing faster then the inner layer in my model. When I use partition to separate my two areas everything works great and I get the results I expect. However when I use the tie function, iterations or merged assembly I have not been able to get the results I expect like i am getting from partitioning my two layers apart. Does anybody know what setting I may be missing that would make these layers interact the same way they do when I partition them apart? The only reason this is a problem is that the next step is to apply this to a more complicated geometry and I will not be able to partition the sections apart in ABAQUS.
Thanks Campbell
Thanks Campbell
