Simba13
- May 19, 2020
- 105
Afternoon all,
I've been tasked by my boss to do a bit of research on timber piles for a Client. The Client is trying to build a small timber dock (residential) on a lake. We've designed and drawn up the framing for this and other projects for this client but we've noted on our drawings "pile design by others", my boss and I are structural, not geotech so we left that to someone else. The Client got another engineer (structural, geotech hybrid) to do a one page calc a while ago, using the Engineering News Record Formula saying that the barge and everything to drive these piles is A OK. That engineer has recently passed away and this guy isn't able to get a permit passed using that old calc. So we're trying to look into it, so we might be able to make a recommendation (this isn't a big town and thus geotechs aren't setting up shop on every corner). I've looked at the timber pile construction guide and it seems like a geotech report is non-negotiable since you need the SPT results or undrained shear strength to get a capacity. I'll probably call the one geotech in town and talk it over but I'd like to at least have enough info for a basis of a conversation. So have you had any experience with this sort of thing? What are the main design concerns? I'm in a low seismic area, are lateral forces a consideration here (very small dock projected area)? I imagine I would need to make sure bearing and skin friction aren't exceed when loaded, but also that skin friction isn't exceeded through buoyancy when unloaded right?
Any tips or tricks of the trade would be very much appreciated.
