Mark Scatoloni
Aerospace
- Nov 13, 2018
- 2
I have a 21-6-9 stainless steel (CRES) hydraulic tube connected to a 6al-4v titanium fitting that is subjected to a 56-day salt spray test per RTCA/DO-160_Sect 14. Should the CRES tube connection be showing "rust" at the contact/interface (for CRES and titan)? Also, the connection has apparently weakened since following the exposure period, is failing a minimum burst-to-failure test. The CRES tube is "bare" and the titanium fitting has solid film lubricant in the bore between the tube OD and fitting ID. no other coatings are present. Any feedback?
