struct_eeyore
Can somebody fill me in as to why, at least for residential buildings with wood roofs, continuous load paths from the roof sheathing to the walls are almost always ignored?
It's also interesting that the section of the IBC that specifies some typical examples of continuous load transfer/blocking (2308.10.7...) is excluded from the FBC - which would otherwise provide at least something for me to point to when questioned by contractors.
Of course, if you do start including blocking and bracing, you're now the only engineer who does that, and start being labeled as overly conservative...
I'm on the west coast - are those of you in the HVHZ encountering the same issue?
