fundiz
- Aug 30, 2005
- 3
I've been told that a torque arm is used on a hallow shaft gearbox in order to prevent the gearbox from wanting to rotate along with a shaft. I don't understand how this can happen if the gearbox is face mounted on a conveyor (the mounting bolts should prevent rotation).
I've also been told a torque arm is strongly recommended on any hollow shaft gearbox. Can anyone explain why?
