penpe
- Nov 27, 2012
- 68
Per ACI D.8.2 for cast-in anchors that will be torqued, minimum edge distance is 6 x bolt diameter. Not torqued min is same as cover requirements of re-bar. Other requirement for side face blowout and concrete breakout strength must be met, which will drive edge distance. Having met the requirements for concrete blowout and breakout is edge distance less than 6 x bolt diameter okay?
The big question is: when is an anchor bolt considered to be "not torqued"? It seems that any time you tighten a nut onto a threaded rod torque is applied, right? Or is it only considered "torqued" if a numerical value is stipulated; i.e. lb-ft of torque required?
