JA
- Jan 17, 2017
- 20
I am designing single angle connections that are both bolted-bolted, or bolted-welded. The supported members are often coped at the top and bottom flanges. As such, is it is your opinion that torsion should be considered on the remaining coped section (effectively a thin rectangle) due to the eccentricity from the single angle? This often becomes very limiting as the remaining section has minimal torsional resistance.
Does anyone have any research or guidance on this matter? I have consulted the AISC manual for single angle connections with limited success as far as guidance on what/if torsional effects should be considered on the remaining section.
Thanks in advance.
Thanks in advance.
