thruthefence
Aerospace
Regarding the Toyota troubles currently in the news; any chance of this being a "drive-by-wire" software (or hardware) issue, as opposed to a strictly mechanical, binding throttle linkage,ect problem?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
That assume an automatic, correct? 'Cause I guarantee I can mechanically overrev a manual...ChrisDuncan said:In addition there's no way you can damage a DBW system by overevving, all are limited at redline in gear and most have a lower limit, 3,000 to 4,000 when in neutral or park.
Isn't that the current intention? Appropriate sensors, appropriate software, etc.? It's obviously not working as well as many had hoped, mostly because determining what's "appropriate" is partially a moving target and partially unknown or untestable.thomasthebird said:The point is with sensors, correctly located, and appropiate software I think we can increase the safety of the car by detecting some mechanical problems. It gives us a capability we never had with 'just mechanical contrivences'.
