albert1
- Jan 17, 2003
- 7
Hi
There is a curved steel truss of 50m span with two steel columns on each side. Transversely, this truss is spaced at 8m for 120m long. May i know how do i check the lateral stability of this long span truss in 120m direction although there are purlins on top of truss and cross bracing at end bay? Normally at both end bays, there are steel columns placed below the truss, do these columns help in lateral stability of the truss ?
