Some factory worker wired my charging adapter backwards so it blew up my charger when I tried to plug the battery in. I’d like to see if I can fix it because this charger is discontinued by its manufacturer. The part that blew out looks to be a SMD resistor, but I’m not sure. I think the heat loosened up some of the outer layer of the board so when I scraped it away with a screwdriver, the copper pads got exposed. What is this component, and is it practical to repair?
