triad transformer
wvw
Computer
Sep 13, 2013
5
Hello Everyone
I am currently working on a project whereby I am building a circuit to drive 2 CFL's using a small DC battery.
However, part of the circuit requires a 176.1mH triad transformer and I am not sure what a triad transformer is and how it differs from an ordinary transformer.
I tried to google this, but it only showed companies manufacturing transformers.
Can someone please explain what a triad transformer is and how it differs from an ordinary transformer?
wvw
I haven't come across the term 'triad' in this context before. At a guess, I suggest it is one with two secondary windings, or a secondary and tertiary.
The obvious question is why a 'triad transformer' would be specified as an inductor unless its reactance is a key part of circuit operation, and why there is no information about its turns ratio. Do you have a circuit diagram that might help people see what the purpose of this component is?
There is a manufacturer (named Triad) that can deliver any kind of transformer/choke you can ever dream of. And quite a few that I never dreamt of.
Sometimes, a manufacturer's name is used instead of the correct/generic name. I think that happened in this case.
Gunnar Englund
It may be to do something about the core construction if it is a three phase unit.During last 100 years, at various stages, transformer engineers tried a triangular alignment of 3 phase cores to reduce no-load losses and to get exceptionally low exciting current ( eg Brown Boverie in 1940's) Last attempt was from Sweden -Hexaformer.com -ABB calls their transformers with such core construction as TriDry Transformers
Hello Everyone
Firstly, my apologies for the very late reply. I was trying to remember the title and also find the video I was referring to in my original post. I finally managed to track it down and this is the URL:
In it the guy was talking about a high inductance triad transformer 1:1 showing on the circuit diagram it has a rating of 176.1 mH.
This is still leaving me a little in the dark as I am not sure what a triad transformer is? And I would also like to know if I can use an inductor with a rating close to 176.1 mH or will that not work?
A transformer manufactured by the Triad Transformer Company.
Bill
"Why not the best?"
Jimmy Carter
What waross (and others) have said. Triad is the manufacturer. Go thru their catalog and find the 1:1 high inductance transformer you need.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Hi
I just want to say a huge Thank You to everyone for all their help. I did what was suggested and found the transformer made by triad online.
I will be placing my order and hopefully have my project off the ground very soon!!
Thank You
wvw
