I'm relatively inept at vibration analysis and frequency response, but I'm trying to predict vibration problems with tube and shell heat exchanger designs. I've followed J.M Chenoweth's guidelines in the Heat Exchanger Design Handbook and have come up with all the forcing frequencies (turbulent buffeting, vortex shedding, acoustic vibration, etc...) and the natural frequency of the tubes based on heater geometry and baffle spacing.
I found a natural frequency of ~104 Hz but forcing frequencies of 1523 Hz and 2469 Hz based on some rough, but relatively accurate cross flow velocity profiles. This is based on an old design and design values. The heater itself has not had any severe vibration issues that I'm aware of during its service. My question is how could these extremely high forcing frequencies affect the vibration of the tubes. Will they excite the higher harmonics and could these higher harmonics cause higher tube deflection and stresses than the fundamental resonance?
Also, for future evaluations, how could higher forcing frequencies (say 1.5 times higher than fundamental frequency) affect tube vibrations from a prediction point of view? I'm ultimately trying to correlate tube vibration with fatigue to predict tube failures.
I know I'm asking about a lot of stuff, but any input would be greatly appreciated.
Thanks in advance.
Thanks in advance.
