I'm trying to scale up an existing air expansion turbine using similatiry laws, specifically getting the same non-dimension mass flow parameter for the scaled up turbine. I know various conditions for the existing turbine and the power requirement for the scaled up turbine.
01 = stagnation condition at inlet
03 = stagnation condition at outlet
m = mass flow
rho01 = air density
a01 = speed of sound
r = tip radius
Non-dimensional mass flow:
theta = m/(rho01*a01*r^2)
k = Cp/Cv
R = gas constant
Enthalpy change:
dh = [k*R*T01/(k-1)]*(1-T03/T01)
Work:
W = m*dh
The only way I can work out the new mass flow is to assume T03/T01 is equal for both and then find the new tip radius.
The question is:
Is it valid to assume T03/T01 is equal for both turbines or is there another method?
m = mass flow
rho01 = air density
r = tip radius
k = Cp/Cv
R = gas constant
Enthalpy change:
Work:
W = m*dh
The question is:
