Turing a non priming pump into a self priming/automatic priming pump
DieselTwitch
14
I have never posted on this site before but find many answers to many questions i have on here.
No I have one to ask directly.
I have the need to install a pump for pond pumping and sump pumping. Im using 2" Motorized valves to select the source... not really part of my question i just wanted to give some background.
For a while I've been looking at 2HP Self Priming pumps.... Having that self priming is a very important thing however the pay off is a dramatic loss in pump efficiency. Best i can hope for with a Self Primer is 50% however with a regular centrifugal pump is 85%. So my idea is this. I want to use a bypass valve,
This valve
to turn this pump:
into a self priming pump
Take a look at my drawing to see what I am thinking.
I need to know if this has any chance of working. the basic theory of this is that once the pump is primed i will see a dramatic rise in outlet pressure (measured by a pressure sensor) and the system will shut off the valve returning the pump to its high efficiency mode of operation.
Thank you for any help you have to offer.
If water carry-over is a problem, use a water ring vacuum pump.
