Twincharging with Screw-Type SC instead of Roots
jbond
44
Twincharging an engine that features a screw-type supercharger (ie it already has internal compression) in my mind has the following advantages and disadvantages:
Disadvantages:
It would still feature parasitic loss when the supercharger is "bypassed" and the turbo is powering away at higher rpm
Advantage:
The efficiency being better than a roots blower, would mean lower temps and more power
Can one of the gurus post their thoughts? PatPrimmer and Warpspeed had a lot to say on previous TwinCharge topics.
In short: what is the suitability of screw-type SC for twincharging project?
PS: I really have the twincharge bug! help!
Crankcase oil has a much harder life than gearbox oil due to blow by of combustion products.
A blower gearbox may see some oil dilution from unburned fuel depending on where the fuel is added to the system. This applies to all oil types
The best oil is the oil you change. Regularily. I put a B&M minicharger on a small block Chevy, back in the mid 1980's, and about a year and a half later, the customer calls me up saying the blower tossed the drive belt and the unit is siezed. I ask "when did you change the oil last"? Bingo, he never did. Rebuild was thankfully light, and from then on every 5000km, the oil was replaced with regular 10-30 engine oil with good results. On my Thunderbird SC, I was using genuine Ford supercharger oil, when I discovered that Ford's supercharger oil seemed to be exactly the same as aircraft turbine engine oil, (Unscientific smell, and finger feel test.) and since then I've used Esso-2380 turbine engine aircraft oil in the supercharger gear sump, with excellent results. (The car now has 265,000km on the original engine.) A lot less expensive per litre too.
j79guy
Well, just a short update on this one :) today I bought an EJ255 which is the 2.5 litre turbo engine as used in the Subaru WRX 2006+ models
Have also decided that I won't do an engine transplant, but I'm going to design a car in Pro-E software and then build it
:) Also, I'm stoked at the price - I got it dirt cheap! $300AuD which is about $200 USD
how cheap is that! spun bearing or something, which doesn't matter cos I'd rip it open anyways~
