Two datums adequate? 1
TWJR
Military
Jul 16, 2013
82
I know typically we use 3 datums, primary, secondary, and tertiary to restrict freedom of movement of features. However, in this case, I was wondering, since there are no internal features (holes, etc), this would be adequately defined using only two datums? I'm thinking that a 3rd datum wouldn't really do anything here...
 http://files.engineering.com/getfile.aspx?folder=a5d899bd-6de0-45a5-87ef-4944de4b093c&file=profile_example.pdf
Any discussion of how it should be tolerance should beg the question "how does it function... what orients and/or locates what... what tolerance liberties and refinements are necessary for ideal function?"
If the flatness and perpendicularity were extracted leaving just the profile all over... max flatness on surface A would increase to .004 and max orientation of surface B to A could exceed .004.
I should have boxed the thicknesses... my mistake.
Paul
