two stroke oils - anti corrosion additives ?
Gerry45
53
Does anyone know what kind of anti-corrosion additives are used in two stroke oils, if at all ? Unfortunately this is a subject which the manufacturers are reluctant to discuss openly.
Ive recently compared the ability of a few oils to prevent corrosion and find it varies significantly between the products. The best seemed to be an oil that was formulated for extreme high speeds and temperatures!
