CowboyBill74
- Oct 11, 2006
- 20
Hello all -
I am afraid that i know that answer to this question already but this forum has been very helpful in the past. I have the pleasure of analyizing an existing two way slab that carries not only uniform loading but also has various pressure loads (uniform loading is dead and live load, pressue loading is from a tank that has 6 legs resting on the slab). My question is this, of course i am under a time crunch, i need a way to analyize this two way slab. The slab is two way continuous in one direction and 5 way continuous in the other. With this type of configuaration i am unable to use the simplified method of analyizing the slab according to code. I tried analyizing it as a one way slab (being conservative) but the slab does not have enough capacity looking at it this way. I tried putting this system into StaddPro but i do not think that i have correctly inputed the information because of the results that i am getting. Does anyone know of a program or a simplified hand calculation that i could use to determine the two way capacity of this slab? I have worked with engineers that showed me how to come up with the uniform load going in each direction by equating the wl^2 for each direction. However i have many tanks (4 in all with 6 legs a piece) do you think that this mythod is still applicable? It would still be a ruff hand calculation but i am running into my deadline quickly.
Thanks in advance for any information.
