Hey...I'm just trying to find out what some of you guys see as a range for the static forces on the lower ball joint stud...
Here's what I have... the static loaded weight if each front wheel is 1320 lbf. Using a 3/4/5 rule for y/x/z. I have 3960 lbf(x-axis), 5280 lbf (y-axis), and 6600 lbf (z-axis) at the tire contact patch.
Now that I have this I set up some FBD to calculate the reaction forces at the lower ball joint to determine the loads each of the lower arms carry... This is also done with various steering angle to determine the max loads each of the arm would see whether in tension or compression...
So based on the geometry of the suspension, I have calculated the following loads carried by each of the links that make up the lower control arm for the max loaded condition... 8512 lbf(Tension) and 13519 lbf(compression), these loads don't raise any red flags, but when I do analysis on the ball joint studs...I am getting ridiculous amount of strain in the material...
For example...the outer lower ball joint I am receiving 0.0229 in/in of strain which based on typical steel MOE of 30E6 this comes to 687 ksi...that's out of this world...and this is based on the factory ball joint design...So either my loads are assumed to be way out there, or there is something that I am overlooking...
So that is why I'm wanting to see what you guys have seen as typical design loads that the lower ball joints sees, which based on the above loads of 8512/13519 is a resultant load of 15976 lbf...
