Keystation
- Aug 21, 2024
- 8
Hi, I wanted to ask the community about my confusion on steel connections. For your reference, I use AISC.
1. Is it possible to have multiple U factor for the same tension members? For instance, a diagonal member will experience tension in two directions. Do you calculate U factor when the load is x dir and y dir separately? Do you use the area of the connection in that direction (x or y)?
2. For angle connections, say both legs are bolted, do you use gross area of the whole section to calculate tension or do you use just one leg that is on the load path. I have seen both. Where people using gross area subtracted by eff bolts hole areas or where only one leg is considered for checks. How do you know which area to use? Does this have to do with eccentricity?
2. Why is U factor applied for tension members. Are there any other scenarios where U factor is applied? U factor accounts for non uniform stress distribution. Wouldn't this happen the same way for shear, compression or flexure whenever the loading is eccentric? How is eccentricity covered in each loading scenarios? After all U is called "shear" lag factor.
Thank you for reading my unorganized thoughts! I had these confusion for a while and wanted to hear other engineer's opinion on them.
