pleckner,
The vessels with 26 psig at bottom is subject of an ASME VIII-1 definition of design pressure in Appeddix 3. The design pressure is not taken at the top, is taken as per the Appendix 3 of the code, at the bottom of the vessel or even lower, at the bottom of the outlet flange face. And 26 psi makes the whole vessel pressure vessel, including the U-stamp.That means the inside vessel from top to bottom is pressure vessel, including the jacket partially covering the internal vessel. The jacket requires U-stamp also because of pressure at or above 15 psig. Please disregard my first reply where I discussed the issue of "foreign" fabricators, qualified to fabricate ASME VIII design vessels, but they are not required to stamp their vessels. That is, the 75% of the world used the code, but cannot endorse the U-stamp beacuse cannot afford a US AIA, doesn't make sence to use US legislation in Korea and the Australian Chartered engineer is just as good as an US AI. Having said that, the U-stamp is mandatory for both the jacket and vessel for 15 psig and above, including any liquid static head.
Hey, chaulklate, howzat for your jacketed vessel?
Cheers,
gr2vessels
