UG NX 10 Drafting Copy prefix and suffix
Guljar14
16
Hi All,
Sorry for my poor English.
Please help me out in this.... recently I have gone through some of Catia V5 sessions,
I have seen a good command in Catia Drafting namely "Match Properties"
and is there any similar command in UG-NX to copy prefix and suffix ??
journals are always welcome!!!!![hourglass]
Guljar Ali Shaik
Designer
Look for something uses the term 'Inherit'.
John R. Baker, P.E.
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Thanks @john,
I have found 'Inherit' in Edit Appended text,
but its been a long to apply each and every dimension
I mean...
Edit Dimension >> Edit Appended text >> Inherit >> and select source Dim.....
is there any other way???
Guljar Ali Shaik
Designer
Not sure if this works in NX10 but just discovered this morning in NX9 how to easily inherit the appended text from a dimension to 1 or more dimensions.
Select the dimension to edit appended text, for instance 2X in the before location than select the other dimensions you want to have the same appended text, it will automatically inherit the text.
The only drawback is that it will inherit all appended text. So need to proceed with some caution in selecting what your inheriting from.
Wayne Huseby
Drafting Checker
Goodrich Corp
Jamestown, ND 58401
