UGZIPC 1
phillpd
780
Is there a version of this available for NX9 ?
NX 9.0.3.4
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
The attached one is the same 64bit one I've been using for a while.
I just tested in NX9 and it works as expected.
There's an image in the zip to show where the menu edit puts the option.
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
Attached are copies of the latest versions of teh UGZip utility (with NX 9.0 you'll need to use the 64-bit version). After downloading the file, edit the extension changing it from .zipper to .zip and then extracting the folder containing the files and the instructions for installing them.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=1eee77ad-1f93-417a-be70-61cb7e1ce5f3&file=ugzipc_new.zipper
Thanks for the ZIP files.
Having issues though ... When I select "Work Part", the loaded part isn't being added to the UI.
Any suggestions ?
NX 9.0.3.4
NX 10 (Testing)
Can't explain that, it works for me.
Anthony Galante
Hi Anthony/John
I installed your ugzipc as per the instructions. Got the menu item "Zip Assembly..." as expected.
When I clcik on it I get the following error message (from log);
The reason C:\universal\user_defaults\application\ugzipc_win64.dll failed to load was:
Cannot load image C:\universal\user_defaults\application\ugzipc_win64.dll
The specified procedure could not be found.
&MACRO FOCUS CHANGE OUT 1
&MACRO FOCUS CHANGE IN 1
&MACRO MESSAGE_BOX -2 Failed to load image - see log file for details
&MACRO MESSAGE_TEXT File name: C:\universal\user_defaults\application\ugzipc_win64.dll
&MACRO MESSAGE_TEXT Function name: ufusr
&MACRO MESSAGE_TEXT
MB_CBS_TERMINATED - pre/post callback execution terminated when action, ugzipc_win64.dll, returned status Error-
I've set the "UGII_USER_DIR=C:\universal\user_defaults"
Any Ideas? regards Paul
 http://files.engineering.com/getfile.aspx?folder=5d8403f6-ac9b-4650-80a4-c8a4be7aaad8&file=ugzipc_error_message.jpg
Did you put the 'ugzipc.men' file in the 'Startup' folder and the 'ugzipc.dlg' file as well as the 'ugzipc_win64.dll' file in the 'Application' folder?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi John
Yes I have put the correct files in the startup and applications folder
Any other ideas?
regards
Paul
That's all I can add to this as that's what I did and it works.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
All
Is there a way to have ugzipc read a path that is longer than the standard 86 characters?
regards
Paul
UGzip doesn't function the same way in a managed mode, so I have submitted ER 7216125. Jump on board, if you think it would be useful.
-Dave
NX 9, Teamcenter 10
