UNCONNECTED REGIONS HEAT TRANSFER ANALYSIS
m0lind04
Geotechnical
Jan 31, 2020
7
HELLO,
i am working on a fairly big and complex model with three instances. two of which are implemented later on in the model.
after installing the first instance and removing cells of the main part, i keep getting the error:
2 unconnected regions in the model.
I have tried to adjust the tie constraints and did everything i could. How can i find the exact location of the unconnected regions?? Is there a way to do this??
Please help! Thank you
To find these regions you can run datacheck with unconnected_regions=yes command. Abaqus will create node sets and element sets for these regions then.
