rittz
- Dec 30, 2007
- 200
I saw a drawing for an underground concrete water storage tank which was approx 20' x 30' x 8' high, The lop of the roof slab was 12" or so above grade. Located 4 or 6 ft to the side of the tank was a 12" dia pipe which extended vertically from a foot above grade down to the level of the bottom base slab (no closure on the bottom of the pipe). It was essentially a deep sump (9ft). What was the purpose of that sump anyone? The tank was in use as a fire pump test facility.
