Has anyone ever seen or worked with a floor slab similar to this? It appears to be metal lath supporting some sort of concrete fill with a wire mesh, similar to stucco wall finishes. The second photo shows where a previously added metal deck and this original floor system meet. The reinforcement appears to have been cut and not re-connected/supported on the adjacent joist which is not ideal.
PS: Metal deck does not exist under the metal lath/concrete fill. Open web joists are ~24" oc.
If there are any references to this type of floor system, any insight would be greatly appreciated.
