Updating Userform TextBox Default value 1
eamint6
3
Hi everybody,
I want to know if there is a way to update a userform text box default value when user enters a string in the related field, i.e., every time user runs the macro, the default values should be the last ones user's entered in the previous run.
Thanks in advance
your script should then save and read the value in a text file somewhere or in the win registry.
Eric N.
Could you please tell me how can I retrieve saved data from Windows registry?
Of course I did! Actually i'm new in vb programming and its difficult for me to apply available methods ( to the CATIA VBA code i'm trying to write. All I need is to save a folder path string to the registry and recall it.
however, thank you for your follow-up "itsmyjob".
