HI, I got a EATON 10KVA UPS and a string of 32 external batteries(13V normal voltage) in operation for 3 years. The other day it lost the input power, the UPS should switch to battery mode and supply the load but it didn't actually. it seems the batteries are empty. I measured the voltage is 430V which is good. The internal resistance is measured as well that is varied from 8 milliohm to 13 milliohm, I know they are deteriorated. But why they can't hold the output for even some seconds? Why the battery mode didn't work at all?
