electronext
Im new here in the forum, and i've learned a lot of things by simply reading all posted threads. So, Thank you.
Can you guys help me on this. We need to upgrade our data center 30KVA UPS to 30KVA SMART UPS VT. this model include an automatic maintenance bypass panel. i attached here the existing electrical plan together with our proposed plan. my question is,
1. can we connect the existing 33KVA AVR before the new 30KVA UPS at the same 100AT lines?
2. Does the AVR consume as much current as the UPS?
3. Will there be any problem if an AVR is connected before the UPS? I mean, the redundancy on voltage regulation? We want to place the AVR before the UPS mainly because, at bypass mode (normal line) we still want the input supply to be regulated.
Any help will be much appreciated.
