Tina a
Bioengineer
- Jan 10, 2018
- 24
I need to run an analysis in Abaqus where a rod is supposed to be placed inside a cylindrical object which is at a certain distance from the rod. Half of the rod's length should be inside the cylindrical hole. Is this procedure possible to simulate in Abaqus? If yes, can anyone give some guidance regarding the use of proper connectors and steps? I really want to figure out a way for this. Also, please let me know if the question is not clear. Thank you in advance.
