I would have posted this in the automotive forum but I thought I would get a more-considered answer here.
As we know, a banjo fitting normally has the threads wetted by the media passing through the fitting. My concern is that in a very clean system, e.g diesel fuel before the high-pressure pump but after the filter(s), there is some possibility that debris from the threads may contaminate the system. In this particular case the female half is a tapped thread in 6061-T6 aluminum, while the male is a conventional hollow banjo-type screw, presumably a machined thread.
In particular, if the connection is loosened and then tighened without flushing, what are the chances debris larger than 2 micron will be present?
Also, are there any general hydraulic design guidlines that discourage the use of fittings with "wet" threads?
Thanks,
-Paul
Thanks,
-Paul
