Use of single pile under a pile cap 9
NewbieInSE
234
Dear Engineers,
Is it prohibited in any code (ACI, ASCE, IBC, UBC) regarding the use of a single pile under a column if the support condition is considered a pin? Or is this matter discussed anywhere?
Note: Assume that, it is required to use pile foundation than shallow foundation due to some reasons.
It's been 20 years since I've done a seismic project... I'm not into them... I do not know why a single pile cannot be used... a double pile could be tricky and should not be an issue, except for high seismic areas. The slab itself can provide restraint of some sort.
However, I was looking for others reviews as the seniors here said that a single pile or two piles cannot be used for a column(in any seismically active area)..
Minimum three piles should be used with a pile cap for any column as per them
This, I think, is a matter of professional preference rather than a hard rule that codes imposed (like using a minimum of 2 bolts for any horizontal member or specifying 12mm thick base plates as a minimum). For seismic areas, the limitation is dependent on type of lateral force resisting system (i.e. SMRF, Ductile shear walls) as far as I know not one of them limits the no. of piles in a pile cap.
I don't see the need for it... there is little to be gained.
