David Choi
- Nov 13, 2018
- 1
I am currently designing the lateral braces for a 3-story building in Philadelphia, PA. The building has a brick masonry facade that could also be used for shear resistance. After calculating the wind loads for the building, I determined the shear stress due to the wind for the first floor.
The mortar used for the brick masonry is Type S. My objective is determining the strength of the mortar joints to see if it can handle the wind shear stress. I looked online for possible values and found it to be around 50 psi for the limit. I was wondering if this is correct?
I used this sheet for reference, page 3, Review of Design Provisions #2.
If I'm incorrect, is there a way I can determine the strength?
