Wendell H
Chemical
- Mar 24, 2021
- 4
Can anyone help me with this problem.
I have an existing RM storage tank system 700 feet from the end user. 3 inch CS transfer line with PD pump at tank.
The raw material is an oil with a viscosity between 1400 and 2000 cP depending upon the temperature.
I have completed my calculations and ran in-plant simulations and am confident my calcs are correct.
The pressure drop needed for a 65 GPM transfer is about 25-27PSI or 175 to 200PSI total.
The existing system PD pump will deliver 120 PSI max at 200 GPM. I can slow the pump down and decrease the flow rate but I still have to overcome the piping pressure drop.
Can I put a second PD pump in the line say at 400 feet? The first pump will transfer the fluid to the second pump and we will see a pressure drop of about 100 PSI. The second pump will then see an inlet pressure of 20-25 psi and finish the transfer to the end user.
On the surface it seems logical but I know I'm missing something huge.
