Hi all. Want to adhere a PCB to a clear polycarbonate housing. Currently looking at UV curable adhesives.
Has anyone got experience with this?
Is it safe to use UV cured adhesive on polycarbonate, without degradation that may cause part failure?
As I understand it, the adhesive (before it is cured) attacks the Polycarbonate.
But after curing it causes no further damage.
Also UV is known to degrade polycarbonate
So problems may arise if
1. Uncured adhesive is left in contact with the part, causing further damage
2. The degradation caused prior to curing is somehow enough to cause the part to suffer long term failure in the field.
Any insights are appreciated
